Re: super a thrust bearing in pices, idling problems
Posted by gene bender on June 01, 2010 at 04:17:19 from (67.55.226.67):
In Reply to: super a thrust bearing in pices, idling problems posted by ctall2010 on May 31, 2010 at 15:13:21:
If the input shaft wobbles you need to but a vushing there as that will help the throttle respomse . I bore them out with a cutter and install a 5/8x1/2 brass bushing makes them work like new again. A good machine shop can do it or you can sent it to me ive done a bunch of them for readers.
