Re: 100 touch control still not acting right
Posted by mkirsch on June 01, 2010 at 05:03:26 from (64.80.108.57):
In Reply to: 100 touch control still not acting right posted by couv on May 31, 2010 at 18:30:33:
couv said: Whichever lift arm DOESN't have a load moves first, then the Lift Arm with the load moves.[/quote:3e249b76ba]
Are you moving both levers? If so, that is normal.
When you move one lever, only the arm connected to that lever should move.
[quote:3e249b76ba]Have to keep the engine revved pretty high to get it to lift quickly.
It is normal for it to be slower in the lift direction than the lower. The reason is that the pump has to fill the entire cavity behind the hydraulic cylinder piston during the lift. When it lowers, the shaft of the cylinder is taking up most of the space inside the cavity, so the pump has to move a lot less oil.
