Posted by Dean Olson on June 01, 2010 at 13:33:09 from (76.203.158.151):
In Reply to: Farmall H, 4th Gear posted by Chief47834 on May 31, 2010 at 18:14:32:
The shift forks should be straight and evenly spaced when in nuetral. Your shifter tip may also need to be welded up. The bearing that holds that assembly may be worn and allowed the whole assembley to drop down just enough that the fork is not engaging. Grab the assembly and lift up on it. It shouldn't move much.This was the problem in an M I had that was doing the same thing your's is doing. I ended up bending the fork so it would work and ran it till the motor spun a bearing. If that doesn't work I would guess that the gears aren't installed correctly. I can't imagine how that could be but I'm no expert. Post a picture of the gear train looking down from the top and the true experts on this board can tell you if it's correctly assembled.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
