Re: Super H hydaulics weak?
Posted by bc on June 01, 2010 at 14:52:21 from (71.158.215.119):
In Reply to: Re: Super H hydaulics weak? posted by mkirsch on June 01, 2010 at 13:04:15:
Hello mkirsh and others. I have a related question for you. If a pump is wearing out to the point of needing replacement, what do you see first? A reduction in pressure below the popoff rating of the system, a reduction in flow where hyd cylinders move slower, or both, or either one (if either which one usually first)?
Thanks, I'm just thinking out loud with my system that always has enough pressure to bump the bypass valves open such as when holding the valve open when a cylinder reaches the end point. Guess I need to invest in a guage and fittings anyway to see what is happening.
