Easy fix The battery needs to be good (assuming it is for now). The fail to start is due to low voltage at the coil when cranking. Small battery cables are usually contributory. The need to be 0gauge cables and solid connections to ground and starter relay. To prove it is the issue, a second battery can be used to jump start the tractor at the starter side of the relay. With the key on, the jumper battery (even 12v) will bypass the electrical system, and not affect the electrical system at all. I be t it starts right up. If you want to see the issue first hand, put a good meter on the coil terminal connected to the key. When cranking I bet it shows less than 4.8 volts. It needs more like 5.6 to 5.8 volts to start. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
