Re: Cub light switch
Posted by Janicholson on June 01, 2010 at 18:45:20 from (64.61.211.204):
In Reply to: Cub light switch posted by 47H on June 01, 2010 at 17:27:48:
The switch body and stem are a ground for the Field. You have it wired on the switch incorrectly.
There is only one terminal for the Field, and one for the Lights and one for the supply for the lights. There are two resistors. One in the light circuit. (for Low beam) and one in the field circuit for Low charge. With a meter, and all wires off of the switch, but the switch mounted, One terminal will be fully grounded in HDB positions, and have a 2 to 3 ohm resistance (or so) in the L position This is the Field wire terminal only. The other terminals will read zero resistance from battery input screw to light output when in H only. The same terminals will have about 2 ohms when in the D position. I hope this clears up the situation. Jim.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
