Well it sounds like either your pump is about shot or the gaskets on the multipule control valve are leaking. The pressure to the PTO might be lacking also. I doubt that since other things are causing it to act up too. The MCV is on the left side down below the clutch pedal. It will have to come off to remove the pump. The pump is bolted to the back of it. Be careful not to pry on it or the plates on the MCV can be warped or bent. There are 2or 3 gaskets that can be blown and an O-ring or 2 to replace when you put it back on. Good luck with this project. Tip When putting the MCV back on if you can get a couple of studs to use for a guide it will be much easier to do without gasket damage.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
