Posted by Owen Aaland on June 01, 2010 at 20:52:59 from (65.165.246.77):
In Reply to: 806 Rear axle.... posted by Dan Swanson on June 01, 2010 at 06:42:54:
To decrease the end play in the axle you will need to remove shims. BUT if your axle is loose it is because you have a bearing that is failing. You need to correct the cause, not just address the symptom.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
