This is the depth control for a Cub 2-way plow. I believe the right hand plow is the same as your single right hand plow. The link has holes at 6", 7", and 8" from pin to pin.
I don't see why you could not make the link even longer. You can also pickup a little less than an inch by bolting the plow to the bottom side of drawbar. If doing that you could also use longer bolts and add some washers.
My plow has no trouble going to 8" of depth. The hand lever can also be moved while the tractor is plowing. That's handy when running out of traction.
If you need a picture of the link, I can do that later.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
