Re: Uneven belly mower cutting
Posted by glennster on June 02, 2010 at 08:00:42 from (75.57.116.142):
In Reply to: Uneven belly mower cutting posted by 7lazy77 on June 01, 2010 at 21:19:39:
check your belt routing and make sure all the blades are turning in the right direction. not sure if its possible on the woods to get one turning backwards, but my hustler zero turn, its pretty easy to route them wrong. then check your blade heights to make sure the mower is level side to side, and then check front to rear. with the blades lined up front to rear, the fronts should be 1/4 to 3/8 inch lower than the rear for a good cut. if you want a handy dandy tool, stop by a john deere dealer and get a blade measuring tool. they are only about 15 dollars or so , but handy as heck. here a pic of mine.
third party image
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
