Re: changing to 12 volt
Posted by Janicholson on June 02, 2010 at 08:04:50 from (199.17.6.222):
In Reply to: Re: changing to 12 volt posted by Jeremy Kamradt on June 01, 2010 at 17:32:34:
The issue with the use of a 6v gen in a 12 system is mostly in two places. The first is that the gen field coils will heat more than desired when used in hot summer conditions. The second is the reduced ability to reach high output (for the gen) and its ability to keep up with lights, or repeated start stop operation.
Putting 12v field coils in a 6v gen will usually eliminate both issues. There are 12v alternators built into the case of generators!
