Re: Farmall H, 4th Gear
Posted by Kevin in MI on June 02, 2010 at 09:33:51 from (148.168.40.4):
In Reply to: Farmall H, 4th Gear posted by Chief47834 on May 31, 2010 at 18:14:32:
If fifth gear is working, the 4th/5th gear slider is installed correctly. Look below on the counter shaft. With the lid off, you should be able to slide the gearset toward the rear of the tractor and check for engagement onto the lower counter shaft gear.
