Re: ih 574 pto question
Posted by Jimb2 on June 02, 2010 at 17:40:18 from (99.240.236.11):
In Reply to: ih 574 pto question posted by jackdonkey on June 02, 2010 at 14:45:13:
Hi Joe, there is only one hydraulic pump on 574,
the MCV valve flow diver splits the hydraulic
feeds:
9 GPM to 3pt, remotes and loader.
3 GPM to PS, PB, PTO, Oil cooler and transmission
lube.
The transfer pump, pumps hydraulic fluid between
compartments in the transmissions and differential
and supplies lube to transmission.
Sometimes PTO problems are caused by a sticky
actuator mechanism. It is valve under the rubber
boot on top right of MCV valve. Lift boot and
spray your favorite lubricant on the valve and
mechanism while engaging/disengaging the PTO
lever.
JimB
