Re: M, 400 fan rpm
Posted by Janicholson on June 03, 2010 at 13:28:25 from (64.61.211.41):
In Reply to: Re: M, 400 fan rpm posted by karl f on June 02, 2010 at 22:07:32:
Mark both pulleys with a marker so you can see them against a piece of tape, or a fan blade with tape and tape on the shroud. (pull the plugs if needed) and crank the engine over counting ten turns of the large pulley. (and counting the turns of the small as well) Slow hand crank turning is easiest!
then it is again simple math to set the ratio. Jim
