Posted by Janicholson on June 03, 2010 at 17:33:34 from (64.61.211.207):
In Reply to: Re: Farmall A Wiring posted by Afarmall on June 03, 2010 at 15:44:52:
I now have enough information to fix the problem! The 4 position switch is not correct for a voltage regulator system. (by the way some Cutout relays had the same box as a VR, and 3 wires as well!) If yours is a new VR, here is the scoop:: Do not use the terminal labeled Voltage regulator. connect the F terminal of the VR to the F terminal of the Generator directly. The F terminal is the smaller of the two on the gen. Connect the Bat lead of the VR to the amp gauge (opposite the lead that goes to the starting switch.) Connect the Arm, or GEN terminal of the VR to the Arm terminal of the Gen. (bigger gen terminal)
The Remaining terminals are just fine. Power in to the same side of the Amp gauge as the Bat wire from the VR.
Tail light, and headlight. are good to go.
The switch will have 2 OFF positions far CCW, and the next position CW from there. D and B should be fine for the lights. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
