Posted by Janicholson on June 03, 2010 at 17:50:14 from (64.61.211.207):
In Reply to: M, 400 fan rpm posted by karl f on June 02, 2010 at 12:51:02:
That alternator will begin to charge when it gets 12v on the #1 terminal. At almost any RPM. It gets its exciter current from that source. If it will not charge till near full throttle, it is not operating correctly. (guaranteed) Putting a resistor of 10 watts 100 ohms in the wire coming from the ignition switch, going to #1 terminal, allows it to avoid back feeding the distributor, thus staying running when you shut it off. Use a small pulley, but the issue is actually the internal workings, not the RPM. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
