Re: Brakes SMTA
Posted by Red Mist on June 04, 2010 at 10:58:06 from (67.142.130.40):
In Reply to: Brakes SMTA posted by Ben Hodges on June 03, 2010 at 16:52:37:
Ben:
According to the Blue Ribbon Service Manual, Form GS-1051, "Brake Service, Super-MTA Tractor", the key measurements are as follows:
Operating Rod Spring (the coil spring on the shaft) Pre-load Dimension: set at a length of 1-3/16 inches.
Free Pedal Movement adjust: 1-1/8 to 1-3/8 inches movement by hand at top of rear frame cover.
Lining And Disc Overall Thickness: Normal: .490" to .505. Minimum: .438"
Hope this helps. Like the others have said, you may have to have the housings turned down anywhere from .060" to .100" to compensate for wear on the friction surfaces.
mike
