Posted by Theman on June 04, 2010 at 13:36:12 from (65.198.133.254):
In Reply to: Re: tractor related posted by mkirsch on June 04, 2010 at 10:26:03:
While I agree with much of what you say and wouldn't tow a tractor myself, the outer brake pinion bearings and reverse countershaft are above the normal oil level. They receive lubrication from oil slung into a channel on each side of the transmission case by oil that is brought up by the lower transmission gears passed to the sliding gears. While being towed in neutral the lower gears don't turn so oil isn't fed to all the bearings. With the engine running, the transmission countershaft is spinning via the constant mesh gears allowing some oil (not quite as much as if the tractor is under its own power) to make it to all the bearings.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
