Re: M, 400 fan rpm
Posted by Red Mist on June 04, 2010 at 16:05:45 from (67.142.130.39):
In Reply to: M, 400 fan rpm posted by karl f on June 02, 2010 at 12:51:02:
Is it a one wire alternator? This is a common problem with the one wire alternator. That is why many guys here recommend a GM 3-wire alternator set up. mike
