Super C leaking Hydraulic fluid into motor
Posted by Dean Olson on June 04, 2010 at 17:00:14 from (76.31.47.68):
I got the pump apart and everything looks good No obvious groove in the pump shaft, no cut orings etc. All other parts look good. This pump was/is working good and very strong. The pump will lift a 7' fast hitch disc off of the ground with little effort. The question is: Can I get by with just replacing the shaft seal? The shaft has no perceptible groove or reduction in diameter. I will get it mic'ed and see what that tells me.
