Re: ih 574 pto question
Posted by Jimb2 on June 04, 2010 at 18:38:09 from (99.240.236.11):
In Reply to: Re: ih 574 pto question posted by jackdonkey on June 04, 2010 at 17:46:20:
Joe, does the flow divider have a neoprene seal on
the top of the spring? Does it work by sealing a
hole in the casting bore?
Yes first priority is to PS, PB and PTO.
I believe the way the flow divider valve works is
that it covers or seals a hole in the top of the
bore until the hydraulic flow exceeds 3 gpm and
then it opens to allow the excess flow to the 3pt
system.
So everything still points to flow divider being
open allowing all flow to 3pt.
JimB
