Re: 1942 farmall H only having 3 gears?
Posted by Owen Aaland on June 05, 2010 at 01:34:15 from (65.174.247.109):
In Reply to: 1942 farmall H only having 3 gears? posted by El Toro on June 04, 2010 at 21:02:33:
36F30 said: (quoted from post at 01:26:49 06/05/10) War tractor that came on STEEL REAR WHEELS so 4th was removed or blocked off.
What do the rears look like? are they like a normal H or are they the originals cutoff with rims added?
5th gear was the gear that was blocked out. The gear was present in the transmission but a bolt was installed through the deck near the clutch pedal to keep the 4/5 shift rail from moving forward into 5th. Tractors with 5th gear have a shorter bolt in that position.
My guess is that you are not finding second and third. the shift pattern is:
R 2 4
1 3 5
