Posted by El Toro on June 05, 2010 at 04:08:39 from (74.103.74.58):
In Reply to: F-14 sleeve removal posted by Seth Boyer on June 04, 2010 at 18:21:35:
I removed the sleeves on a Farmall A using a piece od 2 X2 oak and a hammer. Some pistons came out with the sleeves. Used a torch to get the pistons out. Only needed the rods. The other sleeves came out using the oak and hammer. They're not pressed into the block. If they won't move you may need to make a puller and a puck to fit the sleeve bore. Hal PS: Here's Keith's sleeve puller he made for his Super C.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
