Re: Farmall A Tractor Pulling Problem
Posted by Andrew Z on June 05, 2010 at 05:14:19 from (64.252.148.52):
In Reply to: Farmall A Tractor Pulling Problem posted by Tony (A2, MI) on June 04, 2010 at 19:14:17:
lower the tire pressure to between 5 and 6.5 psi. You prob wont be able to run much for additional weight maybe a 100lbs or so given 150lb driver.
Andrew
