Re: Farmall A Tractor Pulling Problem
Posted by Pete76NY on June 05, 2010 at 08:31:12 from (67.246.156.207):
In Reply to: Farmall A Tractor Pulling Problem posted by Tony (A2, MI) on June 04, 2010 at 19:14:17:
Depending on the track, I will get my tires down to as low as 4 lbs or so...also did he start with the RPMs high? Esp. important with smaller lighter tractors to start the sled moving at low RPM and feed more in as you start to move...even working the clutch well, if the RPMs are up to high it'll spin!
