Re: Power steering 400
Posted by Wardner on June 05, 2010 at 09:37:23 from (207.69.137.25):
In Reply to: Power steering 400 posted by B Steffen on June 05, 2010 at 08:49:13:
Yes, the easiest way is to use a dedicated V-belt driven PS pump. You would need a Behlen or Char-Lynn actuator, automotive PS pump, bracket, pulley, V-Belt, and two hoses. You have a choice of high mount or low mount on the PS pump. Low mount requires altering the fan shroud.
Or you could use all the hardware from a stock 400-450 that was factory equipped with PS. Major items would be Behlen torque generator and the different regulator that replaces the non-PS regulator on a 400-450. I chose the latter route.
Goto caseih.com to see the parts.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
