Re: Cub Light Switch AGAIN!!!
Posted by John M on June 05, 2010 at 12:22:43 from (67.231.160.184):
In Reply to: Cub Light Switch AGAIN!!! posted by 47H on June 05, 2010 at 10:19:30:
If you have a regulator, why are you using the 4 postion switch? You should be using the 3 position switch. I think thats where your confusion is coming from. The "regulator" is probably meant to say "cutout", sop ignore that one and hook a wire to Batt Power and youll be good to go.
