Posted by Zachary Hoyt on June 05, 2010 at 13:36:13 from (184.8.250.192):
In Reply to: hydr. posted by Michael/Cindy on June 05, 2010 at 13:02:38:
If you have a belly pump set up with the push/pull rod all you have to do is put the rod in the neutral position and it will be fine so long as there is oil in the pump. If you have auxiliary valves on your hydraulics the easiest thing might be to remove the belly pump driveshaft on the back of the pump. It is about 4" long as I recall and has a collar on each end. Pull out the cotter pins and slide the collars back on the shaft and it will slip right out. Then you don't have to worry about it. If you have something other than a belly pump someone else'll have to tell you what to do. Zach
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
