Posted by davman1 on June 05, 2010 at 14:06:21 from (205.188.116.73):
In Reply to: Re: cub 154 loboy posted by dan mcdonald on June 04, 2010 at 17:43:46:
Thanks for all your info, I checked the motor mounts today...the 2 l shaped ones in front and the thicker ones in back. All look good with no broken pieces or cracks found..also today I used a gear puller to remove the plate on the front of the trans..I wanted to check the pilot bushing..although not destroyed in any way, I think I will replace it..cheap enough. Any ohter input would be great as I would like to find some reason this happened while I have it torn down this far. Also the clutch plate on this site is $44.00 while the factory one is $199.00???thoughts on that after market VS factory . solid plate Vs spoked model ..once again ..Thank-you for your input.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
