Re: Light Switch Resistor
Posted by gene bender on June 05, 2010 at 19:12:01 from (67.55.226.67):
In Reply to: Light Switch Resistor posted by Cottonwood Valley on June 05, 2010 at 19:04:05:
That resistor was used to ground the field for hi-charge when it had a cut-out. Now that you went to 12v you wont be grounding the field there. You wont need the field wire coming from the generator area as it originaly came from the field when it had a cut-out. Most replacement regulators will cover this in the installation sheet that comes with the new reg.
