Re: Int'l IHC 2000 vs 2001 Loader
Posted by Weldon K on June 05, 2010 at 19:30:53 from (98.16.17.166):
In Reply to: Int'l IHC 2000 vs 2001 Loader posted by Loren in MN on June 04, 2010 at 09:51:45:
I have both. Subframes are the same. Lift arms are the same until you reach a point about 18 inches in front of the lift cylinder pivot point. 2000 had double acting lift cylinders. 2001 could have had double( same as 2000 )or single acting cylinder ( lesser lift capacity, gravity down ). 2000 had two dump cylinders on material bucket(60 inch or wider), manure fork (60 inch), or other attachments. Grease-able pivot pins on bucket, etc. 2001 could have had trip latch gravity dump bucket or fork or one hyd. cylinder for dump. Bucket or fork was 40 inches and fit between the lift arms on dry, non-grease-able pivot pins. Every 2001 that has a hyd. dump cylinder that I have seen in person (including mine)or in photos had damage and welding repairs made to the cross member connecting left and right lift arms. This damage was caused by the dealer ship, who assembled the loader for the buyer, not properly mounting the trunnion where the dump cylinder attaches to the above mentioned cross member. They neglected to drill two holes in the lift arms and install bolts as the setting up instructions directed.I can send you brochure scans with specifications if you like.
