Definitely make sure that you've got the cast center on the right side. If you took it off thinking you'd make the tractor lighter to make a certain weight class, that's your problem.
The engine is offset to the left, making the right side lighter by default. Cubs are the same way, but they're small enough that the weight of the driver pretty much balances them out. A Super A is much larger and heavier, so unless you weigh about 450lbs, it just ain't gonna happen.
Running without that heavy center on the right is dangerous. The tractor will tip over on much of side hill.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
