Re: International 656 hydro (gas)
Posted by Zachary Hoyt on June 06, 2010 at 08:24:04 from (173.86.114.43):
In Reply to: International 656 hydro (gas) posted by Joe Stwora on June 06, 2010 at 08:02:27:
Could be restricted gas. Have you pulled the drain plug on the bottom of the carb to make sure you have strong gas flow? If you do not you may need to check the sediment bowl, look in the tank or try loosening the fuel cap. Often older tractors have rust in the tank.
Zach
