Re: ? for John M or Janicholson
Posted by 47H on June 06, 2010 at 08:45:04 from (76.164.179.49):
In Reply to: Re: ? for John M or Janicholson posted by 47H on June 06, 2010 at 07:53:04:
Okay according to the cub operators manual the right side post on the ammeter as viewed from the back is the battery side (the side wired to the B post of the regulator). The post on the left side is the "Starting switch to ammeter cable". This is how mine is wired. However I did have the wire going to the "battery in" post on the light switch wired to the battery side of the ammeter, so I took your advise and moved it to the non battery side. This is what I get-L no lights ammeter reads 0. H front lights are dim NOW the ammeter remains at 0. D front lights are bright but should be dim and ammeter reads 0. B Front light are bright and back light comes on BUT ammeter still reads 0. The ammeter is the original, do you think all this messing around has damaged the ammeter?
