Re: Update - Super A Pulling Problem
Posted by Tony (A2, MI) on June 06, 2010 at 10:36:04 from (76.249.45.19):
In Reply to: Update - Super A Pulling Problem posted by Tony (A2, MI) on June 05, 2010 at 17:19:55:
The heavy rim is on the right. I cold not keep any additional weights on due to the weight limit. Tires were at 9psi, perhaps they should be lower. Maybe next time we'll put all his weights on and let him pull in a higher class. May not perform that well, but at least he'd probably e moving at least.
