Sorry, Im not John M or Jim but until they arrive this may help,
The Ammeter has two terminals. Lets call one the SUPPLY SIDE (to Battery only) and the other the LOAD SIDE (to loads like lights PLUS BAT terminal on VR or Cutout relay).
Theres only one wire on the Suppy Side, that gets to the hot ungrounded battery post, often via a wire to where the big battery cable attaches to a starter switch or solenoid.
The ammeters other Load Side feeds hot battery voltage to lights and ignition PLUS wires to the BAT terminal on a Voltage Regulator or Cutout Relay, i.e. loads PLUS the gennys output (via the BAT terminal on VR or Relay) MUST WIRE TO THE SAME AMMETER TERMINAL AND NOTTTTTT THE ONE THAT WIRES TO THE BATTERY/STARTER.
If the ammeter is wired correct, if you turn on lights or ignition engine not running, it should swing over to - discharge. If it instead swings to + charge, the ammeter is backwards and needs the leads swapped but stilllllllll only one wire on the Supply side to battery/starter and 2 or more on the Load side, loads PLUS the BAT terminal on VR or Relay
LHBD that switch is for use with a Cutout Relay charging system where the gennys FLD post wires to the light switch to regulate Low versus High charge.........If you have instead a full fledged Voltage Regulator the light switch (3 position, lights on bright or dim) has nothing to do with charge regulation, the VR performs that function and the gennys FLD wires to the VR not the light switch
On a Cutout Relay system (gennys FLD wires to light switch) and LHBD switch, in L position she should charge a few amps at fast idle or full RPM..........In H position she should still charge but even higher then at L........If you go to B or D she should still charge, but not as high since the lights rob some of the current
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
