Re: ? for John M or Janicholson
Posted by Jim Becker on June 06, 2010 at 15:48:39 from (173.57.154.186):
In Reply to: ? for John M or Janicholson posted by 47H on June 06, 2010 at 06:33:14:
47H said: You are correct I do not have a combination rear light only a one wire job. However it doesn't come on until the fourth position.
I don't remember which thread had your switch diagram to go check it. However, your switch probably has one terminal marked TL and another marked RL. If so, your rear light is connected to one and nothing connected to the other. If you move the rear light wire to the currently unused one, your rear light will be on in the second and third positions, and off in the fourth.
