Re: Farmall C - - oil pump priming ?
Posted by gene bender on June 06, 2010 at 18:32:49 from (67.55.226.67):
In Reply to: Farmall C - - oil pump priming ? posted by Pete in Holland, MI on June 06, 2010 at 13:00:36:
If you lubed the bearing journals it will be fine and like you said a few turns with the starter will have the pump making oil every where. I have never had anyproblems getting the pump to work. I like to take the oil pressure guage out turn the engine over till i see oil install and go for it. Make sure the stud on the center of the tappet is clear as thats where the oil flows for the rockers..
