Re: Super MTA Oil Leak
Posted by Wardner on June 06, 2010 at 19:53:45 from (4.154.235.153):
In Reply to: Super MTA Oil Leak posted by Michael Bishop on June 05, 2010 at 18:17:11:
Why do you say "of course". You threw in the hydraulic verbiage which is a red herring. The hydraulic system on a SMTA is totally divorced from the TA and rear frame lube. Moreover, you were vague on the point of leakage.
You probably have leakage at one of the two seals separating the TA from the dry cavity where the TA clutch is located. There are two drain holes from that chamber. They are located ahead of the seasonal disconnect.
There are three holes in the bottom of the flywheel housing that could leak engine oil. They are also located ahead of the seasonal disconnect.
Live with the leakage or split the tractor to replace the TA seals.
