Re: 130 starting problems
Posted by old on June 07, 2010 at 08:09:59 from (4.245.2.30):
In Reply to: 130 starting problems posted by TominNC on June 07, 2010 at 07:12:54:
Coil being hot says that either you left the switch on or your switch is not working any more and you have power to the coil at all times. As far as starting hard that could be a number of things from a carb problem to weak spark or bad new parts
