Re: Farmall A B C radiator fit.
Posted by gene bender on June 08, 2010 at 04:43:57 from (67.55.226.67):
In Reply to: Farmall A B C radiator fit. posted by Mark J in Fowlerville on June 07, 2010 at 18:41:54:
You mite make it work but the bottom is different on the C. The C uses carriage bolts on the bottom where the Aand B uses a stud with a nut on the bottom. You could get by also thop brace should work as its different from the Aand B.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
