Re: 130 starting problems
Posted by Janicholson on June 08, 2010 at 11:49:13 from (64.61.211.195):
In Reply to: 130 starting problems posted by TominNC on June 07, 2010 at 07:12:54:
If you have an alternator on the tractor, it could have a bad diode internally. (or it could be a "one Wire" alternator that drains the battery any way. If a generator, it is likely OK, but may have a faulty ignition switch, or wired wrong. THe points may be gapped wrong, and the coil may bave been overheated now, but may be OK. Fixing the wiring first is most important. Jim
