Delco Distributor Bushings
Posted by Don Kempke on June 08, 2010 at 16:45:10 from (70.41.132.160):
I have a 1952 DC Case Tractor with a Delco Vertical Distributor PN 1111411. The distributor housing bushing is very sloppy and needs replaced. I know that Farmall and Allis also used this distributor.
Does anyone know where I can find replacement bushings? I have not yet removed and disassembled the distributor. I'm guessing there is an upper and lower bushing?
Thanks In Advance.
Don K.
