460 injecter issue
Posted by Richard Hoewisch on June 08, 2010 at 18:25:05 from (206.53.153.181):
Father in law has a 460 utility diesel that has been running ruff. Used a temperature gun found one injecter not firing. Has sprayed it with wd-40, pb blaster, and used a air chisel nothing seems to knock the injecter loose. Tried running tractor to heat area up but nothing seems to help,any help would be appreciated
