Re: Need help disassembling a hydraulic Cylinder
Posted by 47M on June 08, 2010 at 19:09:26 from (67.99.89.129):
In Reply to: Need help disassembling a hydraulic Cylinder posted by Dave in Ct on June 08, 2010 at 18:27:38:
It sure looks from the pictures like if you can get that wire ring out, everything should slide out to where you can see what the problem inside might be.
Having said that, I just got done taking a cylinder from my model 33 loader into a hydraulics shop for repair, after I did my darndest to get it apart. My efforts included hammers, chisels, screwdrivers, vise grips, and eventually even a grinder to try to get the wire ring out that held it together. After finally admitting defeat, and after I figured I had ruined any chance for repair, I took it to a local hydraulics shop to see if they could salvage it.
Three days and $175 later, I had my completely repaired cylinder back, and it works better now than it ever has in the 22 years that I've owned the loader. I learned my lesson.
Good luck with yours.
