Re: Need help disassembling a hydraulic Cylinder
Posted by MN Scott on June 08, 2010 at 20:25:28 from (12.157.197.253):
In Reply to: Need help disassembling a hydraulic Cylinder posted by Dave in Ct on June 08, 2010 at 18:27:38:
You need to drive the end cap [the part the wire retains] inward an 1/8 inch or so and the wire will be easily removed with a screw driver. That end cap can be very hard to drive back but it has to go back to get the wire out. If it feels like its grinding metal inside it more than likely is not repairable without spending many times what a new cylinder would cost. Good Luck.
