Re: Need help disassembling a hydraulic Cylinder
Posted by Brownie 450 on June 09, 2010 at 15:38:30 from (66.43.241.210):
In Reply to: Need help disassembling a hydraulic Cylinder posted by Dave in Ct on June 08, 2010 at 18:27:38:
Looks like a wire ring. Only shows signs of being a multi-turn flat ring at the one end. Do you have a press? I'd stick it in a press-- probably has rust in the groove/ring area. Most of the end caps have an o-ring inside & out.
