52 M hydraulics
Posted by dtkraj on June 09, 2010 at 16:40:57 from (207.190.125.75):
Hi, we have a late M with a belly pump, two way hydraulics, hand clutch, and a 115 side-mount mower.When the tractor gets warm it will barely lift the mower so I drained all 2 quarts of quiklift and put in non detergent 40W hopeing that will help.I have read and heard some conflicting info. With the two-way hydraulics I can close the breather right??, it spits out oil like crazy at times and has always been open.the shop manual I found says 6 qts, but does it all drain out when you change it? I also can"t read that 3-piece dipstick to save my life. I put in 4 qts of 40w and tried to read it but as you feed it down the pipe it gets covered in oil from the insides of the pipe. I will try again hoping that it all has dribbled out of the pipe. Can I trust to just put in 6 qts if I can"t read the dipstick? Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
