It has a two speed power shift in front of a three speed syncro, mid mount hyd main clutch, three syncro range trans. Reverse is not syncro and you will have the three speeds with two speeds power shift in reverse. Ride somewhat better than 86 series due to longer wheel base. My opinion on that. You can do a lot of shifting on the move under no load but is no way full power shift. Full planetery final drive, pfc hydraulics and about 45 gals on hy-tran to keep her going. Power shift (actually IH referred to it as power command) is monitored by a computer called the sentry or watchdog for smooth shift and control of the activating solenoids. Lot more tractor than the 86 series.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
