Re: How do you know for sure??
Posted by IH fan on June 09, 2010 at 19:38:11 from (208.189.39.25):
In Reply to: How do you know for sure?? posted by oldiron29 on June 09, 2010 at 18:44:35:
Handyman said: (quoted from post at 21:17:37 06/09/10) The C would have a C113 engine in it, the SC would be a C123, and I think the 240 is also a C123 but it may have been a bit bigger in bore size.
The 123 indicates the cubic inches, or in this case 122.7 to be correct. The HP increase in the 240 was by other means, RPM, timing, compression, etc. There was only about a 5 HP increase in PTO and drawbar from the SC to the 240. A 113 would probably fit, or other 123 engines from the Super C, 200 or 230 tractors and maybe from other sources, like combines.
What makes you think it may not be a 240 engine?
This post was edited by IH fan at 19:39:51 06/09/10.
